Results 1 to 4 of 4
Thread: UL 520 iST (turbo model)
    Anyone have any comments/experience with the UL520iST (it's a UL520iS with the turbo)? The 520iS has been out for several years but UL Power just started marketing the turbo version in January.
    I'm considering it for my CH750SD. Notwithstanding the slow flight of the 750SD, UL claim there should not be any heat issues, etc.
    Bob
    Eric Page's Avatar
    Toledo, WA
    This doesn't directly address your question, but it's related...
    I have no connection to this guy or his website, but I ran across it while researching engines for my Kitfox build. It might be worth your time to read.
    http://www.myulpower.com/
    Eric Page
    Map of Landings
    Thank you for the info Eric - I've read it and emailed Nate for further, more current information on UL Power.
    Cheers
    Bob
    Bob,
    What did you discover? I am considering either an IO-233 or ULPower engine for a CH750 Cruzer, however the inability to run avgas and some of the other information is concerning.
    John
