Thanks, the FAA AME guidance is exactly the sort of info I'm looking for! Very helpful, and I think I can trim out the private pilot license as a possibility based on the guidance in there, as a special issuance looks unlikely. Will continue to research sport pilot, with backup plans to limit myself to taking lessons under supervision if that's too sketchy or turns out to be a hard no.
