Here is and interesting YouTube video about solar flares . Good history too ! https://www.youtube.com/watch?v=3HzaYMOPra4
Learned to navigate with a map and compass when I was a kid. Haven't found a real need for GPS yet. Maps and compasses don't need batteries and magnetic disruptions can be compensated for with a bit of knowledge and practice. Whizzwheels and a pencil are the same way.
For me, my navigation is mostly IFR: I Follow Roads. :-)
Guess I am a dinosaur. I use sectional chart , compass, look out the window, and the old reliable ADF sometimes for cross check. Yes, there are still a lot of AM radio stations out there. I had a GPS steer me to wrong airport once.
The tablet navigation programs can mostly be used as hand-held sectional charts without a GPS signal. You just have to manually keep track of your location and move the displayed map.
I agree that "children of the magenta line" might be in trouble if the GPS signal is interrupted. And GPS based instrument approaches will be problematical.
I don't think many of you went to the you tube link I put in my GPS statement . There is a lot more to GPS system than navigation !
Video was way short on technical information. The effects of solar flares have been long understood before the gps constellation was established. The video failed to note that the satellites are built with radiation-hardened components and shielding, and have redundancy in key subsystems. Error detection and correction routines guard against charged particles randomly “flipping” bits of computer memory.
