Thread: Help with aircraft identification.
Threaded View
  1. #3
    Aircraft "N" numbers 24118, 28, 68 and 78 are all Funks in different locations. You can use the FAA registry to check them out and see if any 'might' be the one in the pic.
    https://registry.faa.gov/aircraftinq...m_Inquiry.aspx
    This generic pic of a Funk Model B confirms your hunch.
    Name:  funk model b.jpg
