Flying Ron has the right idea.... Find the TCDS for the aircraft. If the Aircraft has a version with a factory electrical all you have to do is copy it. Once that is done it's just new W&B and a pen and ink entry in the logbook. If
during this process you decide to improve on the starter or alternator/generator for more modern ones, it is just a simple 337 for the newer parts.
