Thread: For the Nieuport Builders
    "War-Torn" Portland
    Got bored and needed a Coronavirus Quarantine project... so I used my copy of Solidworks (an EAA member benefit!) to design and build a non-firing, full-scale, replica Lewis Gun. Instructions here:
    http://www.wanttaja.com/Lewis/lewis_gun.html
    Name:  lewis gun on fly baby.jpg
    The Solidworks files required for building can be found at:
    http://www.wanttaja.com/lewis.zip
    Be sure not to shoot your prop off
    "War-Torn" Portland
    Hey, I've got a metal prop. If metal wedges were good enough for Roland Garros, it should be good enough for me...
    Beautiful job!
    On the barrel/gas tube attachment to the receiver, it's okay for that to be a bit weak (mine is a wooden circle glued into a PVC tube, held on by a wood screw). In the event of unfortunate circumstances, that's a fine place for it to break, as PVC pipe is inexpensive!
    The plus of going with the PVC pipe shroud is that one can 30 foot cheat and run a bolt through it for mounting.
    Avoiding politics, the FAA could care less and the BATF would think a wooden gun is cute; it's local folks that might get excited. This is where a 30 foot replica is a good thing, but be aware of where one is. Washington State and Alabama are worlds apart in attitudes of such things.
    That said, I'm glad it's a block of wood with plastic. I've seen a number of blank firing examples that are, um, dark gray by the laws on what a firearm is and isn't.
    Next up: converting your gun to gas so it goes bang bang bang with a flame out of the barrel!
    Replica Lewis Guns
    Nice looking replica. There's a group here on the Independence airport building DH-2 replicas and one has flown. To complete the replica I built a gas firing Lewis. Some photos are attached. In some DH-2 Lewis installations a small wind screen was mounted on the gun.
    Vince Homer
    If you do decide to make a gas powered MG remember that the barrel and breach block get very hot. Any parts made from plastic that are in contact with them will certainly melt. I used high density Masonite for part of the receiver and it begins to smoke after a few seconds of firing on auto.
    Vince Homer
