Thread: Smooth Extrusions
    Smooth Extrusions
    Encountered a weird effect today. I use sketch to draw a circle 4" in diameter, then Extruded Boss/Base to basically generate a "can."
    The problem is, the extrusion doesn't give a smooth surface. It's faceted. It generates a solid that's a set of flat surfaces, rather than showing a smooth exterior.
    Here's a closeup of the problem:
    You can see the blue line of the sketch (a circle) but the Extrusion uses a polygon that approximates the circle. The contour appears to be formed of ~48 line segments instead of a smooth circle.
    Is this an adjustment somewhere?
    cwilliamrose's Avatar
    Nov 2013
    SW Florida
    You can adjust the image quality (in the document's options) to minimize that but if you zoom in close it will always be there. SWx defaults to a higher performance setting which is also lower quality on screen.
    Thanks! I was thinking the "Curvature Generation" selection in the "Systems Option" tab was the thing, but didn't see any effect when I changed it. Yours nailed it.
