Assuming I get this plane (the guy a spoke with at the airport suggested it might be for a $1), the panel is probably useless. Let's assume I needed to replace every piece of avionics in there. Or basically start from scratch. I-pad panel mount system, old used steam gauges, etc. What do I need? I mean, from the FAR point of view.
