I'm space-constrained for running brake and pitot/static lines, so I thought I might be able to combined two into one hole.
I've read the AC and know I'm not supposed to run electrical near, alongside, over, etc fuel lines, but I've never seen anything mentioned about these nylon lines. There's not room to run wire loom over one of the tubes in the grommet that will fit my space. I thought about wrapping one line with electrical tape thru the grommet to provide SOME isolation.
Thoughts?l (and thanks!)
