Quote Originally Posted by melann View Post
While I agree that safety wire will not maintain compression on the bolts, it WILL prevent them from departing the aircraft.
Nope - didn't on my plane. See:
http://cozybuilders.org/Oshkosh_Pres...ert_Center.pdf
The safety wire will prevent the bolts from turning, but that's not worth diddly squat if the hub shrinks away from the crush plate and the hub loses compression. Prop starts moving back and forth on the drive flange, the bolts fatigue, and bam - gone.
