Originally Posted by
CarlOrton
Hi, All;
I’m hoping Ron W will chime in here....
Are the NTSB records searchable for specific brand names of parts that contributed to an accident?
I’m trying to find out the instances of Facet fuel pumps failing and then blocking the fuel flow, causing engine stoppage. If the pump just stops working, fuel will normally continue flowing. I’ve heard anecdotally that there are occasional times that the inner parts come apart, blocking the flow.
I know how to ameliorate the risk, but just curious if this is a 1-in-10,000 occurrence or 1-in-10.
