Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Toxic nature of covering systems?
  1. #21
    Coleman fuel is VMP naptha. (VMP = "varnish makers & painters").
  2. #22
    Yep, just a light petroleum solvent. Naptha, mineral spirits, varsol, stoddard, etc... are all in the same family.
  3. #23
    Jeff Point's Avatar
    Milwaukee
    Quote Originally Posted by Soarmaster View Post
    Sam,
    Did you use the Stewart's wash and etch products to prep the raw alum. that airdrome uses for the ekobond adhesive? Or do you have an alternative prep? I'm watching the Stewart videos and am not too fond of the acid etch idea.
    I'm not Sam but I'll chime in. The acid etch process is for aluminum that is going to be painted and is done prior (immediately prior) to priming. It isn't needed for aluminum that is covered by fabric.
    Jeff Point
    RV-6 and RLU-1 built & flying
    Milwaukee, WI
    "It All Started Here!"
