Results 1 to 10 of 131
Thread: Where Have All the EAB Aircraft Gone?
Threaded View
  1. #23
    Quote Originally Posted by Ron Blum View Post
    Vans is doing well in their market … much better than any of the certificated OEMs are doing in the small, GA market.
    Ummm, well. Not really the case, unless you closely define "small GA market".
    If you look at the FAA registry, it includes the model year for the aircraft. In my January 2019 database, there were 295 2017-model Cirruses, vs. 240 Vans aircraft of ALL models. 41 of them were RV-12 light sports. There were only 72 2017 Cessna 172s.
    Annual "Production Rates" for individual RV models runs in the 3-5 dozens, not the hundreds (looking just at the US-registered examples). There are lots of RV models, of course, so that does build the numbers a bit more.
    Here's a stab at extracting the number of new RVs added to the US registry over the past eight years. It is effected by the FAA re-registration process, but I've tried to compensate for that.
    2010
    2011
    2012
    2013
    2014
    2015
    2016
    2017
    RV-6
    18
    10
    -20
    -17
    -29
    -1
    16
    11
    RV-7 Rate
    84
    72
    72
    56
    45
    44
    53
    54
    RV-8 Rate
    49
    43
    36
    49
    23
    36
    44
    39
    RV-9 Rate
    39
    47
    30
    33
    25
    29
    19
    22
    RV-10 Rate
    37
    39
    24
    19
    33
    34
    31
    21
    As I said, the above table has compensation for the de-registration process. This table shows the net RV fleet size for individual models, with the net fleet size each year for Cirrus. The number for each table is extracted from that year's registration database; model year isn't used.
    2009
    2010
    2011
    2012
    2013
    2014
    2015
    2016
    2017
    Vans RV-3
    211
    210
    205
    196
    174
    172
    175
    176
    169
    Vans RV-4
    1126
    1128
    1118
    1118
    1066
    1063
    1065
    1072
    1063
    Vans RV-6
    1999
    2012
    2006
    2002
    1962
    1965
    1964
    1985
    1972
    Vans RV-7
    901
    977
    1040
    1122
    1173
    1229
    1277
    1325
    1375
    Vans RV-8
    1036
    1084
    1123
    1165
    1204
    1233
    1272
    1319
    1342
    Vans RV-9
    464
    501
    543
    577
    603
    635
    667
    687
    706
    Vans RV-10
    238
    273
    310
    331
    353
    389
    423
    453
    473
    Total RVs (ex. RV-12)
    5975
    6185
    6345
    6511
    6535
    6686
    6843
    7017
    7100
    Cirrus (All Models)
    3698
    3808
    3917
    4047
    4148
    4319
    4536
    4794
    5258
    I don't include the RV-12 in here because many are SLSA or ELSA. Later RV models aren't here, either, but there are yet low numbers for them.
    In any case, there ARE more RVs in the US registry than Cirruses...but the RV series dates back to the 1970s, and the Cirrus just in the past 20 years or less.
