Originally Posted by
champ driver
The way I've read the regs are that if you are exempt from the transponder in that particular airspace, then you are also exempt from the same airspace concerning ADSB.
That means you can fly your Cub in the mode C Veil without a transponder and ADSB, but not actually in Class B or C airspace.
Remember Class B, and the Veil that goes with it are two separate airspaces, and with different requirements.
As I'm now reading the regs, you are right for the most part, except that there is a difference in the construction of FAR 91.215 (transponders) and FAR 91.225 (ADS-B-out) that will have the following consequence:
Aircraft without engine-driven electrical systems and without ADS-B-out will be barred from flying above ANY underlying Class B or Class C airspace, AT ANY ALTITUDE.
Currently, aircraft without electric-engine-driven electrical systems and without transponders are barred from flying above underlying Class B or Class C airspace only up to 10,000' MSL.
Also, under the new rules aircraft with no electrical system and no ADS-B-out won't be able to fly above 10,000' MSL under a Class B or C shelf. The only place this would be an issue appears to under some outlying Class B airspace near KSLC.
I've put too many words into this topic already; I'll let you (everyone) look over the regs and puzzle out why I came to the above conclusions.
I'll just say that it's a function of FAR 91.225(e)(2) and how it appears to be intended to interact with the rest of the regulation.
https://www.law.cornell.edu/cfr/text/14/91.215
https://www.law.cornell.edu/cfr/text/14/91.225
All this is based on the assumption that both 91.215(b)(3)(ii) and 91.255(e)(2) are construed to apply ONLY within the lateral limits (i.e. within, above, or below) Class B or Class C airspace. This is an assumption that seems reasonable and realistic and consistent with how the FAA has treated the existing transponder regs.
The truth is that the "or below 10,000' MSL" clause in 91.215(b)(3)(ii) seems utterly useless. It seems to have no application whatsoever. Yet the fact that it was carried over into 91.255(e)(2) definitely complicates the interpretation of this regulation.
Sorry it took so long to take to this point of clarity on the how the regs work-- the language is kind of complicated.
Steve
