Lots of wings attach the ribs via glue + nailing through the vertical member. That's true of the Acey Deucy, and, I believe, Paul Poberezny's Baby Ace, and the Pietenpol, for example.
Just in case it sheds a little more light on the subject, here are the instructions for the Acey Deucy: http://zoemertech.com/ad/acey_deucy_building_info.pdf
As for the loose tolerance between rib opening and spar, gluing a shim would be one approach, depending on just how big a gap you have.
