Results 1 to 7 of 7
Thread: rotax 503 fuel use
    Aug 2015
    rotax 503 fuel use
    those who have or are flying with a rotax 503 what is your average fuel burn
    I am putting one on my project and have a 6 gallon fuel tank, I am not sure if I should add another tank or not
    George Sychrovsky's Avatar
    Shirley MA
    Two strokes like Rotax burn 0.1 gal per hour per HP that means 503 at normal 75% power setting will burn 4 gal per hour
    Disclaimer ; opinions of others will vary depending on what they’re selling.
    http://the-grand-design.com/
    FA40
    You may not have found this info yet, cdlwingnut?
    file:///C:/Users/Owner/Desktop/OM_%20447%20UL%20SCDI_503%20UL%20DCDI_582%20UL%20D CDI%20mod.%2090_ED02.pdf
    Aug 2015
    Quote Originally Posted by Mike M View Post
    no is there a link to it?
    You linked to a file on your own PC, Mike. Does this work?
    http://raanz.org.nz/techproject/rotax/d00286.pdf
    Brrrmidji , Minne-SNOW-ta
    6 gals will git you there...
    You need another to get back....
    Small fly-ins don't always have gas...
    PS I'll be squeezing in ANOTHER 5 gals on Cross country flights ,more weight more fuel.
    FA40
    THAT'S FUNNY! Thank you, Ron. Yes, I can believe i did that.
    https://www.rotax-owner.com/en/suppo...nd-503-engines
