those who have or are flying with a rotax 503 what is your average fuel burn
I am putting one on my project and have a 6 gallon fuel tank, I am not sure if I should add another tank or not
Two strokes like Rotax burn 0.1 gal per hour per HP that means 503 at normal 75% power setting will burn 4 gal per hour
Disclaimer ; opinions of others will vary depending on what they’re selling.
http://the-grand-design.com/
			You may not have found this info yet, cdlwingnut?
file:///C:/Users/Owner/Desktop/OM_%20447%20UL%20SCDI_503%20UL%20DCDI_582%20UL%20D CDI%20mod.%2090_ED02.pdf
You linked to a file on your own PC, Mike. Does this work?
http://raanz.org.nz/techproject/rotax/d00286.pdf
6 gals will git you there...
You need another to get back....
Small fly-ins don't always have gas...
PS I'll be squeezing in ANOTHER 5 gals on Cross country flights ,more weight more fuel.
			THAT'S FUNNY! Thank you, Ron. Yes, I can believe i did that.
https://www.rotax-owner.com/en/suppo...nd-503-engines
