Many thanks Matthew! Just the sort of alternative I need to consider. I once dropped a vw engine out, disassembled it, sent the heads out and put on new rings. Re-assemled, it ran fine. I will continue to research alternatives. My first homebuilt will likely be my only homebuilt, so I will try to choose wisely.
