Chuck: I would highly suggest that you download and read the SDS sheets on Imron and it's various components before you settle on using it. It is highly toxic while being mixed and sprayed. I had a friend that 20+ years of randomly spraying Imron and other toxic paints with just dust or filtered masks, died of various problems brought on by having less than 20% lung function due to inhaling the fumes and particles. A forced air mask and suit are required to shoot it due to it's some of it's components.
Couple that with it running in the 500$ a gallon or higher range, there are less expensive and less toxic products out there.
