The CG numbers for the engine sound a bit off. From your description, the CG for the engine and prop combination is 9.5 inches from the firewall? That would indicate that the the CG point of the motor would be just about at the trailing edge of the back cylinder. CG should be more like the aft side, or center of the forward cylinder.
