I just watched Dick Kohler's latest "Hints for Homebuilder's" about ELT installation and testing.
Does the FAR required annual testing require an A&P or FAA certified avionics shop/technician to sign off the test for a homebuilt aircraft, or can the owner (not necessarily the builder) do the test per the FAR and sign it off themselves?
Thank you and happy flying!
			 ELT Testing and Annual Sign Off
