I worked as a volunteer parking campers for several years. You should have no problem finding a spot in handicapped parking. I would suggest when you check in explain your request and they will summon someone to guide you into a spot. All you should need is a handicapped parking sticker for your unit. From there, there is regular handicapped bus service to get you into the show. Hope that helps, Glenn
