The lightest uncertified Dacron from Aircraft Spruce should work. With perhaps two coats of dope or acrylic exterior house paint. I would definately rib stitch or aluminum pop rivet (if metal ribs) the fabric securely to the ribs.
Fabric adds weight, so check for aft weight shift.
