Results 1 to 10 of 173
Thread: Norm's Flying Boat UL Flight Test Progress
Threaded View
  1. #33
    Jan 2012
    Quote Originally Posted by Norman Langlois View Post
    New floats applied I hope the differences are all positive. The others originally tapered going aft then needed the upper 2 inch deck to have enough displacement to be stable. They became heavy,15#. These have more displacement and weigh less than 8# with the support frame , bare no fiberglass Name:  20180506_170425_resized.jpg
Size:  93.8 KBName:  rear view.jpg
    I like the rear float design with no bottom curved surface. It could possibly be improved with a step at the angle break. Keep that edge sharp, not rounded. Hope that works for you. If needed I can make further suggestions.
    Tell is more about the wheeled cart. Is it ground handling only?
