Matthew Long, Editor
cluttonfred.info
I stole the idea for the wheel chocks from someone else. I glued the parts together so there is no chance anything will come apart when I don't want it to.
Sorry guys took me a while to get back here.
Here’s a photo of what’s in my FP202 right now.
As I understand it, the existing panel that’s in the airplane now will have to come out with the fiberglass fuel tank. Why? Because it’s built in with the existing tank.
We will be replacing the tank with a stainless tank & rebuilding a new instrument panel.
I want to keep it simple. I’ll be using an iPad mini with ForeFlight.
So, what would you guys put in a new panel?
Airspeed indicator, altimeter, tachometer, CHT, EGT, fuel gauge, as a minimum. Oil pressure and temp if a 4-stroke engine. Compass if you plan to go anywhere.
Lightest weight and lowest cost are going to be digital LCD gauges (Tiny Tach, TTO, PPGMeter, etc.) for the engine function. MGL Avionics makes some simple LCD units with all your engine functions in one gauge and a combined ALT/ASI in another. GRT also still makes their simple EIS monitor and the two-stroke model is quite affordable. For analog gauges, Westach quad gauges are neat and you can find them with tach/CHT/EGT/volts and even tach/CHT/EGT/ASI (70 mph for ultralights only). After that there are plenty of options but the many individual gauges start to add up and the more functions you can eliminate (wire/cork or sight gauge for fuel level, little mechanicial compass, maybe do without EGT, etc.) the better.
cluttonfred.info
That is the Viking View Engine Information Display. It monitors and displays everything related to the engine and electrical system.
https://www.shop.vikingaircraftengin...?categoryId=-1
The plane is covered with ceconite and painted with Stewarts. The stripes are vinyl, custom made but inexpensive.
http://www.avgrafix.com/index.html
I'm ordering some 3inch vinyl custom script lettering for the cowling, "Highlander" in white. I think it will balance out the front of the plane with the strips. I bought the N numbers seen on the tail from the same company.
https://doityourselflettering.com
Thanks, Trailka. I think your last link should be https://doityourselflettering.com/
cluttonfred.info
