My Composites Structures & Construction book is up on Amazon
I’ve been working with Aircraft Composite materials & construction since the early 90’s
It’s a technology, art & science where my Learning & Capability has been on an exponential path since the start. I’ve given demonstrations & talks at local EAA chapters, worked on various Composite Home built aircraft all the way up to putting the skills to use with Pratt & Whitney and NASA where I served as a composites technical focal on a high demand 2 year Nacelle technology project.
I Actually started a book on composites years ago but it was not until the release of my TIG welding book where I got a re-kindled interest in finishing the book. Like the TIG book this Composites book is offered in Kindle (digital) and Paperback versions and written in a to-the-point format.
This book is written from the perspective of someone who has the combo of: Industry Experience, Embry-Riddle BSAE, Home built Aircraft, Hands On Fabrication and true eyes open DIY Ingenuity. I Hope this can be a valuable resource for anyone working with Composite materials / structures for Aircraft, Auto & Marine applications
https://www.amazon.com/dp/B07466P3SW...0&linkCode=kpd
ASIN: B07466P3SW
ISBN-13: 978-1973890133
This book has a broad range from Beginners to Seasoned Composite Designers & Fabricators.
Composite Construction can be an Idea Fabrication method for:
- Aircraft
- Cars
- Motor Cycles
- Boats
Work with a construction medium that will do want you want it to with out an up-hill battle to gain every inch.
Easily Achieve Complex Structures with minimal Tooling & Facilities.
In this book you will learn about:
- Shop Safety
- Tools
- Raw materials: (Fiberglass, Carbon, Cores, Films, Fillers, Inserts)
- Jigs / Fixtures & Molds
- Wet Layup & Prepreg
- Kitting & Flat Patterns
- Bonding & Joining
- Finishing
Order this Book Today & Get Started on your Journey
Note: you can also read Kindle Books on:
Hope this can help all the Homebuilders out there.
Spencer Gould
EAA #466275
EAA 203 VP
Technical Counselor: Composites / Firewall Forward.
This week the composites book Kindle version is only $.99, that's 80% off.
https://www.amazon.com/Composite-Str...=UTF8&qid=&sr=
Support page created for Composites Book
https://gouldaero.com/pmc/
Project examples, Composite material suppliers & tools.
