Note that the ”A” in AGPS stands for “assisted”. It’s as real a GPS as any other device. Because the cell network knows exactly where each tower is, it uses the cell network triangulation to give your device’s navigation applications a faster reference point lock while its actual GPS chip is looking for satellites.
Ever have your “real” GPS turned off and travel cross country in a jetliner with it in your bag, and turn it on on the other side of the country only to find that it takes some time to locate the satellites because it’s hundreds of miles away from its last known location? That’s where AGPS shines.
It’s as real a GPS as any other you’ll use.
http://ipadpilotnews.com/2015/12/ipad-real-gps/
~Chris
Sent from my iPhone using Tapatalk Pro
