Tires and tubes, rotax water necks, 10 gallon tank
Selling off some extra parts I don't need.
I have 2 rotax water necks and new thermostat. A 10 gallon tank and bracket from a Hawk Arrow II, and a pair of 15x6.00-6 tires and tubes.
One water neck is straight up, the other 90 degrees to the bolts. The tires are in excellent shape, only landed on asphalt 5 times. I put on bigger tires for rough terrain.
