No idea who/what Job Path is. There are restrictions for the FAA, TSA, and DHS dealing with felonies. Others posted the list. The look back period is generally 10 years; you would have to read the details to find if ten years from offense or ten years from end of time served.
Your best bet for employment is likely with a small mechanics shop, not the airlines or corporate to start. Because of the SIDA issues others mentioned.
(One of the better mechanics I have used was a convicted felon, but that was twenty years in the past)
Good luck,
Tim
The SIDA restriction (and the DC-3 rules which mimic the same text) are ten years from the date of CONVICTION.
