Correct Frank. The original had a flat face on the cut out. I am doing my best to replicate it.
Dale Cavin
Florida Panhandle
I have finally completed engineering and assembly of the root end of the right upper wing.
Dale
Dale Cavin
Florida Panhandle
I'm continuously impressed on how you're elevating the basic plans and "kit" to something really special.
Refresh my memory - are you going to have the center section cut out and mounted permanently with the cabanes and slide these wings into it, or the standard two big pieces to slide together?
Frank, if I understand your question, the wing is split in the center. The rear spar slips between the two plates on top of the rear cabane A frame.
That's why the face plate on the pilot cutout does not go all the way to the end of the spar.
Here is a photo of the sheet I added to the bottom, for access to the nuts and for the cabane mount plate to fit.
The whole section not covered by aluminum in this area will remain open.
The "design" I came up with will not require a large panel to be removable to access the centerline bolts. Just this opening in the back, and small access doors in the covering for access to the front nuts.
Did this answer your question?
Dale
Dale Cavin
Florida Panhandle
Here is a photo of the spar assemblies on the cabanes.
Dale Cavin
Florida Panhandle
Actually, you answered the question without quite understanding it!
Jeff's Nieuport 17 actually has a permanent section where the center section always stays on, and he has a sort of splinting system to slide the wings onto them.
Yours is like mine in that's it's two wings that meet in the middle all by themselves.
We were supposed to be out of town this weekend, but plans got changed. Today Rose and I started on the aileron leading edge.
I made a test piece for the wing aileron cutout. Looks pretty good.
Dale
Dale Cavin
Florida Panhandle
Finished the aileron tip leading edge and riveted it in place. This little piece is a real pain.
Dale Cavin
Florida Panhandle
It's official. I hate you.
My leading edges never, ever came out that clean.
Finished the right aileron leading edge today. Lots of fiddling with just a few parts trying to get it to look decent.
There is about 5/16" gap between the spar and the aileron leading edge. The compression strut bolt just cleared, but covering would interfere, so I cut a slot for the bolt head.
I also stole an idea from the Culpeper N28 guys and added flanges around the aileron hinge slots to attach covering. I will likely add a brace at the rear of the outer flanges for support. The inner flanges are supported by the rib and I think OK as is.
Now on to the wing trailing edge seal.
Dale
Dale Cavin
Florida Panhandle
