This pertains to E-AB aircraft.
1. Under what circumstances does the Special Airworthiness Certificate cease to be valid?
2. What is the impact of the original builder removing the data plate?
3. Is there a way forward after the original builder removes the engine, de-registers the N-number, removes the data plate and donates the project to an EAA Chapter?
Thanks in advance for your wise counsel. -glen![]()
