3/22/17, Back on plane today. Finished some welding and then started the jigging process.The fuselage starts to narrow right behind the cockpit so I think I am going to line up the front half parallel and weld all those cross tubes in before I start the narrowing process. I started with a center line, then found the center of the upper (plane is upside down at this point) longerons and then just started squaring everything up. I will finish locking down the front half tomorrow and start cutting cross tubes.
Jim
