I wrote a VisualBasic program that converts Excel to vBulletin, but the vBulletin code didn't work here.
Dale, what did you use to create the table? I don't see an obvious button in the Advanced editor. Did you write it in HTML vs. the vBulletin code? I tried HTML a while back, but it didn't seem to work, either.
EDIT: Ping! I was in Source Mode, not WYSIWYG mode. I see the options are there in the latter. I'll give it a shot.
Thanks!
