Hi,
What I use on my Gardan Minicab is a surface mounted female 3 pin din micropohone connector wired direct to the battery. It is mounted on the cowling and is a simple job to wire or connect the male plug to the battery charger or a solar panel which works well. Just plug in when required. Nice and easy and inexpensive.
padrecolin
