If you believe .009" runout is acceptable and you are convinced the crank is otherwise good, you can shim the prop to track true. That was pretty common on the old tapershaft Continentals as very few of the flanges would actually track true as most had suffered a prop strike and needed some help getting the prop to track properly. Manila envelope paper works really well as a shim.
-Cub Builder
