Change language from German to English
Hi,
I have downloaded and installed Solidworks, it is not activated yet. During the installation process I choose German as the language. Because most of the Solidworks forums are in English, I would like to change Solidworks to the English version. I assume I have to reinstall it.
Since I haven't activated it yet, can i just deinstall the German version and install it again or do I have to activate it first and then "return" my license to DS, and reactivate it?
Thanks
Klaus
SOLIDWORKS Support Volunteer
You don't have to reinstall the software.
Since you installed the software in a "foreign" language (for me English, as opposed to American, is already a foreign language
). here's what you have to do in English - you'll have to use the equivalent in German (that I assume you can translate better than me
Go to Tools > Options and under the System Options tab choose General (the default).
Then check the following unchecked boxes:
Use English Language Menus
Use English Language Features & File Names
You will have to exit and restart SolidWorks for the change to take effect.
Best of luck.
Thank you Jeffrey, it helped!
Klaus
