Originally Posted by
brothapig
Well, it sounds as though I at least have an answer.
So, the student version obtained through EAA does not and will not/can not utilize the toolbox as it relates to fasteners. At least I can stop trying!
I played around a bit with some of the options discussed here. I downloaded a fastener from McM (STEP format), opened it in SW, saved as a part, and was able to add as a component in an assembly. It appears, however, that there will be no changing this part as far as length, thread, etc. after insertion; and any desired changed will require the import of the actual correct fastener.
Does this sound correct?
