Originally Posted by
Eckertwa
Hello Bob,
One of my big hang ups is the finishing process. I've taken the EAA's two day seminar on composites and the short one at Oshkosh (a couple of times). These were great for the learning the basics of layups and joints but they didn't go over the finishing.
One of the first steps in my Jabiru construction manual was to sand down the interioir of the pre made fuselage. They stated this is needed to clean up any rough fiberglass that might cut or scratch you in the building process. I couldn't help myself; I turned a three hour sanding task into 30 hours of turd polishing.
I'm also concerned that I might leave things too rough and regret it when it is time to do the finishing.
As as you can imagine, not knowing where I should be on the "make it smooth" or "slap it together" scale has me somewhat paralyzed in my kit building progress. Any advice?
I also have questions about: fuel tanks, hard points, trim tabs, and other misc items.
Ill look into getting Andy Marshall's book.
