Hi all,
Do any of y'all have any long term experience with wrapping the exhaust pipes to help keep the temperatures down in side the cowl, reduce heat transfer to wires, hoses, oil, other engine components? I've heard that the increased temperature of the pipes causes them to deteriorate faster than non-wrapped pipes. Others say not so - the deterioration is caused by moisture trapped under the wrap. What is your personal long term experience?
Thanks!
Hofacker
