A little more progress. Forward cabanes cut and fit (with a slight trimming needed).
Port lower wing fit.
I "adjusted" the wing structure positions and got them squared to within 1/16" tips to tail post. I need to make some spacers for the lower wing attachments to hold them in position. The upper wing will be held by the cross bracing between the front cabanes.
I drew out a plan for the forward upper cabane attachment and will transfer that to 16ga steel sheet. These will wrap around the compression strut and extend down the side of the cabane far enough a bolt will be below the wing covering.
Dale
