EFI engines will certainly run poorer when they retard to avoid the pinging. Clearly you could measure this (and frankly the electronic controls could tell you a pretty good estimation of "octane" as a result).
I'd avoid reinventing the wheel though. THere's already a ton of stuff out there on 100% ethanol in RVs and lots of info on flex fuel in auto engines.
