Well, to be honest the reason I didn't reinforce the other side of the step U is I wasn't sure if my first solution would work. I just cut a piece of thick tubing of the same diameter as the longeron as wide as the step guide, cut it length wise, and then using a screw driver and other wedges that seemed to work widened it until I could get some purchase on it. Then I beat on one end of the tube until it was flat with a hammer. I have no idea how it turned out to be just what I wanted - a J shaped piece of tubing that fit over the longeron. It actually goes around half of the longeron, poking up through the fabric underneath.
All the bad force is upwards, and I really don't want to put a hole in the longeron if I can avoid it. I reckon it won't elongate and it sure won't slide. Missing the hole on the way out results in a mark on the fabric - the thin aluminum won't catch on a shoe or boot.
The position of the hole is such that if a toe drags or pokes hard into the hole it's on the rear.
I may well reinforce the front of the U, though. I've got the scrap for it, and now I know how to make the piece. The only time I throw away scrap is when it has stuck into my skin. I have used some of the tiniest pieces for things - heck, I've used the thin trimmed pieces about an eighth of an inch wide as a grabber for washers that have fallen down.
A couple other notes - painting the plane with latex has been a blessing. Since the fuselage is exposed to the elements (my Wonder Tarp Tent blocks the sun, which is the big deal, and most of the rain), dust and junk collect on the plane. Cleaning it is as simple as a little soap and water.
Running the brake lines through the gear was far more of a chore than it should have been, but I've been missing drama in my life of building so it was kind of refreshing. It seems entirely too simple - drill two holes and run a cable through them.
Heck, Rule 11 of building, "Cut nothing until you have to" made things easier, as I've got a huge amount of brake cable to feed through the holes before I get to the sheathing.
Time for the Tool Hunt. What's required? A little allen wrench to loosen the brake line from the brake itself. A 3/16 inch drill bit. No problem! Open up the bit holder - one missing. Son of a...start looking around the work table. Found it! Oh, it's in terrible shape. That's why I didn't put back in the drill holder. I needed to replace it. Hmmm, forget it, I can go one bigger if I can't find the replacement bit I know I bought. Maybe it's in the storage shed.
Open up the socket set briefcase to get the allen wrench to loosen the cable from the brake. Pull out wrenches - one missing. For the love of Pete, are there evil gnomes messing with me at night? Crap in a hat, it's a conspiracy! Grumble a bit about how it's a pretty important tool and impossible to replace without buying a whole 'nother wrench set. Easy to lose, too. Something I should have placed where I could....oh, I did. I've got a plastic bin from a fishing tackle box that I keep all the nuts and bolts required to put the plane together kinda sorted to purpose. I put the allen wrench in with them because it's small and easy to lose.
What a clever fellow I am! Good thinking!
Hmmm, drill bit. Drill bit. 3/16 bits are something I've used a lot, and I know I bought several. Last time I used one is right before I got the replacement drill (needed a new battery and it was cheaper to buy the identical drill with one than a replacement by itself)....check the old drill. Sure as heck, pull out the old one and there it is, and in good shape! Slap a battery on it and I'm all ready with the bit in place!
Drill the holes.
Getting the wire into the top hole is no problem. How to get it out of the bottom one? Try grabbing it through the hole with a looped twisty tie. Nope, too big with the cable in it to come through the hole. Try grabbing it with a bit of safety wire looped. Impossible. The cable doesn't want to bend for me. Run the brake cable through the hole all the way to keep it in one place and out of the mud. Drink some coffee and wipe sweat (it's approaching 95 degrees in the tent). Notice the end of the brake cable is at the bottom of the gear leg. Ah. Run safety wire from the bottom hole through the end of the gear, wrap it around the end of the brake cable, and use it as a guide to pull the cable through. That wasn't such a chore was it?
The other leg, however, isn't cooperating. The cable doesn't want to pop out of the end of the gear, no matter how much I twist it about. Try the loop catch thing, which works about as well as the last time, which is to say not as all. Maybe I can go the other way? Run some safety wire up the leg from the bottom hole to the top. Aha! This I can loop and catch pretty easily with another bit of safety wire. Wrap and pull it through.
Time spent? Two friggin hours. Two hours to pull a cable through two holes, twice.
