i am considering a purchasing a used ,flying kitplane. that is not amateur built. was built by the kit plane manufacturer. has had several owners after the factory built it and then sold it. and is ifr equipped. annual condition inspection is current.
the airworthiness certificate reads experimental exhibition.
any restrictions on where and when i can fly this aircraft?
thank you very any information
