Results 1 to 10 of 11
Thread: Riveting
Threaded View
  1. #8
    The original design was a glued wing, I have plans for an all metal wing and want to use a 3214 CherryMAx rivet to attach all the skins. The fuselage is already designed to be built using such rivets so I am trying to see if using them to attach wing skins is acceptable as well. I will look up the FAA circular as advised in the posts.
    Here is why I am confused. This technical data was pulled from the FAA circular AC43.13-1B and CherryMAx technical data sheets. It clearly shows the CherryMAx is much stronger.
    AN427 100 Counter-SunkHead MS20427 ShearStrength psi10000
    CR3214 5056 ALUM. ALLOYQQ-A-430 8740 ALLOY STEELAMS 6322 A-286 CRES AMS 5731 CHEM FILMMIL-DTL-5541PLAIN COLOR CAD PLATEQQ-P-416TYPE II CL. 2
    Shear strength 50,000 PSI
