Page 8 of 9 FirstFirst ... 6789 LastLast
Results 71 to 80 of 81
Thread: I'm confused about the maintenance and annuals on an experimental I purchase.
  1. #71
    Right but another Condition inspection is not needed. All that is needed is to look over the discrepancies and see if they have been addressed, then sign the log book. The Condition Inspection has been done. Another is not needed.
    So you agree that a condition inspection can not be "signed off" with discrepancies?
  2. #72
    The problem there is that the A&P has to make an entry in the logbook stating, "I certify that this aircraft has been inspected on (date) in accordance with the scope and detail of FAR43, Appendix D, and found to be in a condition for safe operation." The operating limitations require that or similar wording. Any discrepancies and it's not "in a condition for safe operation" at that point so that logbook entry can't be made.
    My personal experience is that I open up the airplane and do the routine maintenance stuff and fix the stuff I find before the A&P arrives. He gets there, goes through the airplane, says, "Fix this and this and this" and goes away.
    I fix the items and give him a call. He comes out, checks my work, then puts sticker in the logbooks with the "condition for safe operation" wording and signs it. I then give him pieces of green paper.
    This is often done in a day, or might take ~2 weeks or more depending on what was found.
    And 91.403(b)also requires all aircraft maintenance be performed as prescribed under applicable regulations including Part 43.
    Do the operating limitations prescribe maintenance rules or just the inspection?
  4. #74
    True. But most of those things aren't things that would cause the failure of an annual inspection, or would be quick fixes the IA would fix in the course of the inspection. But yes, the IA could pass it with discrepancies that the owner could fix himself.
    An IA does the inspection but may or may not do any of the repairs. The repairs can be done by any qualified person. The reason for discrepancies list is so that the owner can choose any and all of the specialists needed to complete the repairs.
    In the case of E/AB, the owner can choose anyone or himself for every repair, not just the list of preventive maintenance.
    My original question was : what if you decided the fabric repair was too much trouble and you decide to simply sell as is?
    I believe an FAA attorney might say you are required to transfer a list of discrepancies to the buyer.
  5. #75
    Nov 2012
    No IA needed.
  6. #76
    No IA needed.
    Yeh, my discussion with Dana was referring to Type certificated aircraft in that comment.
    For E/AB, an A&P or owner with Repairman can perform the 12 month inspection.
    But the inspection is separate from repairs and lubrication. The person who signs the record for the 12 month inspection is NOT required to be the person that completes the repairs or service.
    In the case of E/AB, anyone can do the repairs (major or minor) without supervision or any inspection of the completed work (as I see it). This is unique to E/AB.
    A major change might require an inspection from the FAA or DAR. But a major repair is not a major change.
    I am still sifting through the rules today.
    I believe it all starts with FAR Part 91 which details flight and maintenance and inspection rules for airplanes*.
    I am now trying to find the regulation that requires an E/AB owner to retain and hold the Operating Limitations.
    I think the Operating Limitations must be linked with the Airworthiness Certificate somehow, but what is the regulation?
    I don't think FAA Orders are regulations, but this is where I am a bit unclear.
    *ultralights are "vehicles", not airplanes, so ultralights are exempt from Part 91
  7. #77
    I think y'all are typing past each other!
    Let's say that I have an A&P look over my aircraft, and he spots that the throttle cable is seriously binding or frayed. At that point he says "whoa, that's an unsafe condition" and if I've handed him my log books writes that he did the inspection and found it as a descrepency. He doesn't write it's in a safe condition to operate.
    Why would he write anything in the log book? Because he's trained to write in log books any time he does an inspection. Chances are that the vast majority of the time he deals with type certified aircraft and that's where his mind is!
    Anyhow, so I replace the throttle cable and bring it back to him.
    Naturally he doesn't go back to square one and start the whole inspection over (assuming the repair is done in a timely manner); he notes it was repaired, and assuming that was the only gig that would cause it to be unsafe in his opinion, then puts down the Magic Words.
    The inspection date for the twelve month clock would be, if I understand things right, when he signs off on it as in safe condition, not when he did the initial inspection.
  8. #78
    The difference is the mechanic assumes some liability for your throttle cable installation.
    If you did it wrong and he didn't find the flaw, he could be held responsible because he is supposedly more "professional" and is open to a law suit from your wife or son if you are dead.
    If you sign it off and return it to service, he would not be liable for that repair.
    More mechanics would do inspections if not held liable for owner work. That's the whole point of my alternative sign off comments.
  9. #79
    Bill, I notice you use the phrase "return to service"
    How would a person that doesn't hold an airman certificate return a homebuilt to service? How could they be held liable if there is no way to track them down after the fact?
  10. #80
    I don't know if a Homebuilt owner needs any airman certificate, but for Type cerficated aircraft a Private certificate will do.
    "A person holding at least a private pilot certificate may approve an aircraft for return to service after performing preventive maintenance"... (43.7(f) )
    It is very clear that parts of Part 43 do apply to E/AB such as appendix D for the inspection. So I don't see why other parts of 43 would not be allowable or required as well.
