I am surprised that the FAA's proposal to severely restrict what can be stored in a hangar, even excluding all but "final" assembly of a homebuilt aircraft, does not have more comments. There are 715 right now. EAA has many tens of thousands of members. I think there should be a lot more voices raised about this proposed rulemaking.
This is an fyi that the comment period for the FAA's new Hangar-Use policy is ending on Friday, 05 Sept. If you haven't commented on this yet, please do so. The proposed policy can be found at:
http://www.regulations.gov/#!docketD...=FAA-2014-0463
Click on the Blue text "Non-aeronautical Use of Airport Hangars" to read the policy, and click "Comment Now!" to add your own comments.
My interpretation of this policy is that it severely restricts and disallows many of the common activities that currently take place in the airport environment, not only from an aircraft building perspective, but they also make implications as to the size of other items that you may commonly have in your hangar. They explicitly mention a "small" refrigerator as an example, but as worded this could easily be interpreted to include the size of your workbench or air compressor, for example.
Many of us have excellent airport managers that are supportive and reasonable to work with, but it is clear from the comments on this proposal that many airport environments are actively hostile towards GA, and EAA activities in particular. I found the comments from the Boulder City Airport Association to be particularly illuminating:
http://www.regulations.gov/#!documen...2014-0463-0452
