Results 1 to 7 of 7
Thread: How's the Weather (Grounds)
    gbrasch's Avatar
    Arizona
    Hal, how are the grounds looking? Sure could use some of your moisture out here in drought stricken Arizona.
    Glenn Brasch
    KRYN Tucson, Arizona
    2013 RV-9A
    EAA member since 1980
    www.airportcourtesycars.com
    Joe Delene's Avatar
    Wisconsin
    I think it's been a good season so far for growing crops, to much water in some places. It's great out today. Hopefully it will be on the dry side the end of July. There are a fair amount of skeeters out now, early A.M. and evening for the most part.
    Fastcapy's Avatar
    KOSH
    It is pretty wet right now in Oshkosh. We had a very wet June, last I heard it was the 3rd wettest on record. A lot of our other local events had problems with parking because the fields they normally use for parking were too soggy to drive vehicles on. I know a lot of farmers are not able get in the fields either because it is so wet. We are getting more rain now as I write this... Hopefully this rainy weather pattern ends soon and we can dry out a bit.
    May 2012
    Medford WI
    Is there a new protocol to follow if Camp Scholler is too wet to get in? After Sloshkosk, I am hoping there is some alternative ideas for all the campers.
    Jeff Point's Avatar
    Milwaukee
    Quote Originally Posted by izznsky View Post
    It's wet but not that wet. I was just up there last week, and while a few areas might be soft, it's nothing like Sloshkosh 2010. I wouldn't worry. Things tend to dry out around here this time of year anyway.
    Jeff Point
    RV-6 and RLU-1 built & flying
    Milwaukee, WI
    "It All Started Here!"
    Fastcapy's Avatar
    KOSH
    Just saw on the local news since June 1st it has rained 30 of the 38 days here in Oshkosh...and the next 10 days look wet too. Hopefully this weather pattern ends, Not only for AirVenture but for my sanity as well!
    Aug 2014
    Shipshewana, IN
    It wasn't nearly as bad as Sloshkosh, even so by the end of the week the west end of Elm street was so muddy the pump truck couldn't get to the port-a-johns to empty them, by the time we packed up they were pretty ripe! Just a suggestion, maybe before EAA adds more "improved" water/electric sites for RV's they should "improve" the roads for everybody
