The rules for an annual for a GA and a Condition inspection for a experimental are not the same. The wording logged into the log book are different as are many other things. Experimental does not have to comply with any standards like a GA airplane.
It does not matter if the airplane is two days or two years out of annual. Its all the same.
He did not ask about ferry permits.
Tony
