See http://airventure.org/app for details and download links, etc.
Hal Bryan
EAA Lifetime 638979
Managing Editor
EAA—The Spirit of Aviation
Hal, it there a way to ID this version? I have had the older version for awhile. It told me there was an update and I clicked to update, but the whole app froze and I couldn't get out of it. Had to shut down the app and restart. I think I got it, as I am seeing forum times now, didn't before. FYI (iPhone 5)
Glenn Brasch
KRYN Tucson, Arizona
2013 RV-9A
EAA member since 1980
www.airportcourtesycars.com
Hmm - sorry to hear about the freeze, let me know if that happens again. If you have forum times, then you have the most recent build currently available from Apple, which is 1.1. That one went live on iTunes on Monday. We handed off version 1.2 to Apple at that time, so expect one more version from them once they approve it...
Hal Bryan
EAA Lifetime 638979
Managing Editor
Glenn Brasch
2013 RV-9A
Hal,
I've been playing with this app since it was released a couple of weeks ago. Knowing that it was a pre-release version, I didn't voice my concerns, but now that it's live, here you go:
The update process is horrible. It does not run in the background (even if you click background.) If I close the app while running in the background, it seems to stop updating, requiring running again. If I remain within the app while running it in "background" it runs but takes a really long time. Worse, it's impossible to tell if it actually worked or not, and it allows you to run the complete (several minute) process even if you just ran it, rather than tell you "no updates" or similar.
All this while on my home wifi network or strong LTE network. How this will work on site is anyone's guess, as both the EAA wifi and the carriers signals are abysmal during the show.
Sorry to be so negative but this thing really needs work.
(version 1.1 on Verizon iPhone 5 iOS 7.1.1 and iPad 2 iOS 7.1.2 wifi only)
Jeff Point
RV-6 and RLU-1 built & flying
Milwaukee, WI
"It All Started Here!"
Hal:
Android 4.4.2 is working just fine so far. I've just downloaded it. Will let you know more as I work with it. I'm on a home WiFi network behind a slow DSL provider and it seems quite responsive thus far.
Bill
I'm sorry to hear that, Jeff - it absolutely doesn't match the experiences I've had in testing across multiple devices and network type over the past three months. The background update feature is meant to let you keep using the app while the updates are downloaded, not necessarily to let you close the app and do other things. When the update completes, you'll see a dialog box that pops up to prompt you to install what you've just downloaded, which takes a fraction of a second at that point - that's how you know the update worked.
In my experience, on an especially slow network connection, the longest update time I've measured is just over two minutes - I've never seen anything even remotely close to "several minutes." From here on out, we're going to do our best to limit those updates to twice a day, unless there is a major schedule change or serious issue to fix. Hopefully the utility of the app will be worth putting up with at most 4 minutes of "horrible" every day.
Hal Bryan
EAA Lifetime 638979
Managing Editor
Hal,
FWIW, the app has been updating and working fantastic for me. The only issue I have ( and ii am sure it is me or my settings) is that I keep getting the same notifications over and over again on my Ipad 3.
Thanks for everything!
rick
Hey Hal
I have an antique iPhone (3GS) that I have jailbroken and unlocked for travel so I can use local SIM cards (instead of my Canadian one). It only runs IOS 6.1.6. Is there any hope for a compatible version of the AirVenture app for it? If not, I guess I'll have to carry around my Samsung too, just in flight mode (what a PITA :-)
Cheers
Mark
EAA 367635
President EAA 245
1979 Maule M5-235C C-GJFK
RV-8 C-GURV (Sold)
Bearhawk #1078 C-GPFG (under construction)
Thanks for the feedback, Rick! There are a couple of bug fixes with respect to notifications that are forthcoming, so it may not be you...
In the meantime, if they're getting to be too annoying, you can disable them by going to Preferences, Notification Options, then unchecking the ones where you're seeing duplicates.
Thanks!
Hal Bryan
EAA Lifetime 638979
Managing Editor
