I am fairly certain I've not seen anything remotely like a charging station either a EVSE or even just an electrical outlet on the grounds you could plug into in the public parking areas.
Plugshare shows that there are two stations at the UW campus at 727 Algoma. You could park there and take the bus down.
It also shows Bergstrom Nissan accoss highway 41 from Camp Scholler has three (two in front under the awning and one behind the building).
